Why do no games have 4 player split screen anymore?! 1/4 of the screen each... on a 22" TV... that was fine.... Nowadays no-one even does 2 player split screen on a 50"!
screens have gotten massive but resolutions haven't increased as fast. dat 320x280 4:3
If you could get hold of the original machinery used for a good price, then yes, if you had to make the machinery AND the games, no
kinda like how nike and reebok etc kept all thier old shit and started remaking it for basically nothing and selling it to gen y douchelords
Actually they usually have to redesign the moulds etc from scratch as all that shit gets destroyed. theey also make small redesigns to make the shoe cheaper to produce.. and ruin the sillhouette in the process :(
Sup wasteland brahs?
i like my theory better
Guys short notice, just found some wheels in Sydney which i might drive up and get this weekend. Will 18x10 +38 fit stock rear guards r33 gts-t?
XD9's... And I know I should man up and get +18 but my car is immac and don't wanna roll guards /nohomo
Edited by colourclassic
You will need to roll the 10+38 if the car is lowered. Get the guards rolled, you don't even notice the difference visually. Flared is a different thing.
Your car is immac?
Let's be realistic here, it's a 20 year old jap car that is common as a pom with bad teeth.
You aren't driving a hand painted rolls royce with a single stroke coachline that can only be painted by one guy on earth.
If you want it to look good, be a man and roll the guards... Or leave them, shred a tyre and rip the immac guard in half going up a driveway. Either way suits me really.
See where I'm going with this?
Get +18's XD9's only look good in 18x10+18 or 17x9.5+17. The other sizes all have no lip
Your car is immac?
This man knows wassup
Your car is immac?
lolz i knew was gonna cop it for that! 18x10 +38 has pretty decent lip, i'm not going for hellaflushworks, and i'd probably put some widers tyres on the rear...
Next question... Will four wheels/tyres fit in my shitty old japanese bomb with a driver and passenger?
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
