what do you need?
the cape grim scotch dry aged was nice, heaps nicer than the mb4 sirloin, i know what i'll be buying next
Anything you recommend but not much of it. 2kg would be enough
check clutch bracket isn't loose / snapped as it's a big weak spot in 20 year old R33's with tough clutches
just get under steering wheel (your short-ass could probably stand up under there so that part is easy) and push with hand to see if bracket moves
Brahs,
How to diagnose possible rooted clutch master / slave? Getting it into gear is quite a feat these days, pedal feels a bit spongy too (fluid and clutch line is new)
lolololol...
This exact issue is what I'm trying to get sorted out at the moment... swapped cars with Borci for the day while he takes mine for some diagnosis and poking and prodding at Racepace. Am enjoying this GTR but workmates are like "Oh, you got a new car.... It looks a lot older than your white one :/ "
Even with my foot the the floor, my clutch wasn't 100% disengaging... it comes and goes with its severity, especially when it gets warm, so don't want to risk getting stranded at Winton or DECA when it started playing up in the past.
Also: Dropped off my rear wheels at OTR this morning... Ended up deciding on 265/35R18 Achillies 123S which are meant to be better grip than the new RSRs, last for a while, and are a bit cheaper as well. $220 fitted.
what do you need?
the cape grim scotch dry aged was nice, heaps nicer than the mb4 sirloin, i know what i'll be buying next.
why you guys eating at orchard road anyway? food's mediocre at best.
I was in the area and hungry. Who travels 20 minutes for food when they are hungry? Wasn't too bad and was pretty cheap considering the district.
thats seems a good price. especially for the size. have heard mixed things though, so let us know how it goes at track/DECA
kind of.
I kept telling them not to merge, so it created a new Youtube user under my gmail account. Now that gmail and youtube are merged, you can see the "user" or "account manager" as *enter real name here, from [email protected]". and it also has a feature to track what computers the account has been accessed by, so now poeple have an easier way to get your IP addresses and real name yayyyyyy.
I sense a lot of spam and account hacks coming soon.
Skype and MSN did the same thing; I was pissed. I had a Skype and an MSN account...then they created a new Skype account for me, which merged both my MSN and Skype contacts...yet retained my old Skype account at the same time. So now there's a couple of ways to login and the messaging system is a bit screwed up thanks to dual logins. Dumb shits.
I'll have to get a step ladder first in case I can't reach
Thanks also Simon for your empathy, even if your post was in no way helpful to me lol
And. Now that my final report and lab reports are out of the way, i can finally catch up on anime. And with heaps of time on my hands...
Outbreak Company
Machine Doll
Ars Nova
Kill la Kill
Coppelion
Strike the Blood
Golden Time
Kyoukai no Kanata
Yuushibu
Is there anything else i should be watching? #@kaitoukid
Haha. From what's not there... Yowamushi Pedal. Maybe Tokyo Ravens but I'm not sold yet.
started using skype recently and had noticed that. good thing no one uses MSN anymore.
MySpace4lyf
Also inb4 get a new car
Get a nice fresh falcon bro
+1 annoying as f**k, as time goes on going to have so many f*kn different logins to everything then you need to remember work logins as well haha
also, did squats / legpress / leg extensions Monday, could barely walk into work today :\
Edited by UNR33L
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
