Just finished all the seasons of breaking bad. Easily the best series I've ever watched!
the wire... get on it
...except maybe The Wire
not sure is srs as youtube blocked at work...
(could be the family guy bit about "the wire" being overrated, or a srs "the wire" clip)
pls enlighten
HOWEVER
the wire > breaking bad
and not that's not #hatish.. breaking bad was phenomenal, the wire was just better
I just said Simon 3 times in the mirror and there he was
I tried that with biggie smalls... didn't work :/
pls enlighten
HOWEVER
you were almost right. was clip of family guy when breaking bad tells the audience to never stop talking about Breaking Bad.
and yes, The Wire is very good. haven't watched any breaking bad though.
my balls are breaking bad right now.
pls enlighten
HOWEVER
Will check it out. I feel like there's a hole in my life for watching it for so long lol
Tekstep is on this weekend. farkin so excited. weather isn't looking too good though :(
national park, next to rivers, toilet block (none of that portable shit), good food, 90's Brighton-esque Drum'n'Bass... party on Wayne
work on the car.
tho given up having it ready by deca this weekend,
not looking like seat will have mounts.
still new lights, indicators and such can go in.
so all left to do is the seat and harness for Nats.
haha i'm very much #unilyf... but instead will be working in the morning for dem sweet penalty rates.
then i will be joining the zombies in the library.
or not if i cbf. oh well one exam down, three more to go!
Hi guys, I have arrived, you appear to have missed me. I understand, it's natural.
I've been M.I.A. since Friday night, been working on the car... I now have happy fun time mods :) Yay!
Now, responses to your queries...
A little mad :P mainly at myself though, I've got my HD3+ in my hands right now, but left the MicroSD Card on my desk at work so can't play with it! Meh, $35 cheaper... *shrug*
lol suck shit simon
How about you go suck a f**k
What happened to simon
Nothing.
Address him with 'SIMON' instead of 'simon' and he'll appear.
Shutup
I was waiting outside your bathroom window, so was right there anyway... Wasn't really too much effort to appear for you.
3 of him just appeared. Should I be worried?
Be afraid, be very afraid....
I'm just smalls, so it's less than half the work to make it happen.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
