was going to meet up with a mate in st. kilda last night, nek minnut the moment i get to st kilda i get pulled over. T'was a tactical response van lool. Said it was a random licence check and then that my rear window tint was too dark and also couldn't see my p-plate but let me off with a warning. And also that I had donkey kong hanging out the back.
My 235 federal 595s are fairly chunky on my 9.5" (zomg dangerous)
The 235 nittos stretch nicely for mad e-points
Well now you've got me thinking... I've been looking at either Nitto NT555 in 255/35R18 or Federal 595 in 235/40R18 to fit to my 18x10 XD9's. By what I've heard, the Nitto's run narrow-true and the Fed's run wide, hmmmmmm
Yeah it ruined the last few days of my holiday :(
Lucky it's not the hemorrhaging type!
That sucks but phew that it's not that type. Where'd you contract it from? I got it from Mumbai airport. :/
I had the main fever for two-three weeks and then a two month recovery. Fkn sucked. :( Definitely worse than when I had cholera.
Copped a couple of mozzy bites in Singapore, nek minut headaches and lethargic as fark, then sciatica in my legs. Still hanging out for it to be flu/cold instead, as I don't really want a multi-month recovery.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
