Don't listen to Hamish mate he's angry at the world and the popularity of D1Rs. They are a great looking wheel, but like all cheap wheels, will have your wheel balance issues above 100km/he unless you get frequent wheel balancing.
I get cheap wheel balancing and alignment so not a major issue on that front. Just can't decide on which one to go for. Dish or concave? In terms fo fitment they'll both be pretty similar going by pics.
Do like. but dont like the outter bolts. paint that shit black.
as for gloss or matte... matte will probs go out of fashion soon
True that mate, good point. Might consider getting the studs black too, didn't think of that.
If the wheels are brand new in matte black, is it as simple as getting a place to clear coat them to make them gloss? Or do they ahve to strip the matte off and re-colour in gloss black?
Ahhhh I was thinking the exact same Varrstoens as what you've got but the only offsets they offer are +20 which, believe it or not, are too aggressive for the fat VE guards. A bloke had 19" Varrstoens like yours on his VE and he eneded a lot of guard work apprently. Tough look though.
you can get custom offsets made just email them thats what i did got custom up front
Really?!?! f**k yeah! Do I contact the aussie distributor or Varrstoen directly?
And do they do them in 20s? 19s Are too small for the big VE body :(
Pulsar is up and running, hopefully pick it up tomorrow. Will put up a vid of first start tonight. nothing sounds better than lumpy cams and an incorrect base idle. aw yeah.
Engine will make track debut at Sandown Christmas
Dat silent exhaust tho
needs straight pipes :woot:
haha it's loudish up in the revs under load but I like the silent killer spec atm :D
straight pipes is just stupid loud some people on forums have done it lol
Just add them on facebook and send them a message, main guys name is John I think
Dat photo!
Dem photo skillz!
  • Like 1
