Mad sms
There was also that time you promised to take me around Sandown in an SLS. Empty lies.
Ah lol then.
Lol shuttup man. If I had it for myself the only thing I would be doing is sau joy rides lol. It's probably why then wouldn't give me one lol
ok so I need some help
seems I'm in the company kiris Kringle this year.
avoided last few years as boss was OS.
anyhow $10 gift for a random female,
I'm thinking chocolate, but any better ideas?
I suggested a autographed picture of my car to some ppl at work but judging from the laughter that was not the best idea.
and when I suggested to the organizer some random S14 used car parts worth 10 dollars I got a look of disgust,
so I'm beat for ideas
bottle of wine, body shop body butter, cookbook, manicure kit, tea from T2, candle or candle holder, oil burner, reed diffuser with oil, phone cover, seedling/herb growing kit, cool mug/jug
or chocolate...
jason thinks he can import asian red tailed catfishes into australia.
lol must not have had any experience with aqis.
I can make one.
A cat, a red fish tail.
Job done, he can pay me couple million dollars.
Buy her period pain Panadol.. Record the reaction
a packet of maxi pads too?
With these suggestions, think I'd just deny that she's my Kk when she tries to guess....
Marty...venus fly trap in a small pot. Got one for a KK in primary school and I still remember it as one of the best gifts I've received. Legit fun until it dies.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
