3x0 "many happy returns" mini-ep (christmas special?) released over christmas, but yeah 3x1 "the empty hearse" came out new years day. i think 3x2 is tomorrow.
downloading as we speak lol, can't wait. been 2 years since season 2.
titman: i think gs
couple of blokes I know went to summernats and posted the event schedule + photo's etc on facebook...
Shit I knew it was THE bogan event but I didn't realise just how low an IQ it was actually aimed at.
schedule was basically:
4 hours of burnouts then 1 hour of dyno queen faggotry then 1 hour of drags then 48 hours of burnouts, then 1 hour of dyno queening then another 65 hours of burnouts followed by some burnouts and then the burnout finals
how f**king stupid would you actually have to be to find that shit interesting for more than like 5 minutes?
photos's were basically 8 million cars with heinous paint jobs, MASSIVE wheels, rubber band tyres and turbos, blowers, plenums etc sticking out of the bonnet then smoke, some fugly haggard bitches with thier tits out, more smoke and bogans in 80's shoes, white framed arnettes, thin singlet tops and what looks to be the male equivalent of pedal pushers
leigh has GS.
Not sure if posts related
:'( I am a bit of a bogan though, drink VB and drive a V8 M8! Did I mention I've been to summernats 4 times? :P
And yeah got the GS brah how come? had it 2 years still going strong love it.
Edited by UNR33L
missurs was like: "I heard summernats was on this week, didnt you want to go?" strong unaware.
decided no Phillip Island for me on 1st of Feb. get car done then compete in championships.
inb4 broken driveshafts
lern2beer fgt
I remember watching a video a few years back where some stupid woman went and was documenting her experience as degrading to women... Honey, you were sitting on the back of a ute in a tank top at Summernats, what were you expecting to happen?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
