I need to install a double din head unit, speakers in the front and back, a sub and 2 amps, anyone know anyone/place that installs all that for a good price and does a good job?
I asked jb hifi how much to install all that and they said $650, even i know thats a rip off.
f**k that for a joke. $200 is a metropolitan tow, assuming you even need one once a year lol
applies to every car you drive though, so if you're in a mate's car....
or if you're like me, leaving them headlights on ever so often.....
I agree. Biggest rip. its for people who dont know how to change a flat, jump start or cant stsrt tge car when its flooded. Other than that, its a tow from regional areas.
Also, can use for other cars ONLY if you upgrade cover to a higher level. Which was quite pricey... I got missurs to upgrade for 1 month when we drove to NSW, then downgrade.
You've driven mine, at 270rwkw it only just hangs on to 2nd gear with quality 265 tyres and the 1.5 way. E85 powered turbos come on fast and strong; you'll definitely want those 285s! I'm still very happy with my power for a street car; no desire to upgrade or change it.
That being said, a good right foot controls how much boost you get, so you can always go all out on the tune (within the limits of the clutch) and train that foot. Are you going to have a separate 98 tune or is yours a flex tune?
Gearbox tolerance for power is a piece of string...plenty of people pushing your power levels through these boxes safely; they handle a lot. Others can break the a box with standard power. This is where not so grippy tyres and a soft clutch are your best friends.
This... With 290rwkw @ 1.4ton on 98 I ended up ditching e85 for street duties as it had more than enough.
e85 only for special occasions lol
If only this one wasn't nearly 5k over-priced. Has D1R's with it tho.
http://www.carsales.com.au/private/details/Nissan-Skyline-1998/SSE-AD-2427313/?Cr=19&sdmvc=1
that looks dodgy as, why not even wash a car prior to posting pics for sale? dirty as engine bay, why need 3 air fresheners
plus 13500
ha
  • Like 1
350 minimum.
Yeah went in for a tune on 98, came out of the shop with a e85 tune lol
Yeah might just end up using the 98 map mostly if its too much power for me
your 98 map will be spastic anyway lol
my issue was cruises etc, and that I was using manildra e85 which is only available from one place.
If I go e85 again it'll be united
EOTD they are light cars, and as such 300rwkw is a LOT for street.
they don't actually need 370rwkw just to move them like leigh's cruise liner :P
Yes will be interesting.
On the old turbo i got bored quickly on 280rwkw.
Also an issue with the old turbo on the track was the powerband, sure it came on fullboost at 4,000rpm but then it would run out of puff at 6,000.
New Turbo should give a much wider powerband of 4,500 rpm to 8,000 rpm
Will have to take on leigh from a roll on the new setup once its finished :D
Bitch plz, put me on a hub dyno I'll be making 500rwkw trollface.jpg (nah but srs "430rwkw supra" made less than mine at a certain dyno day.. didn't crack 350 at chasers)
Bring it on! definitely more chance on a roll though that's for sure I've gone my brother a few times from low speed I'm gone by the time he boosts or he just hits boost and wheel spin city cos of the light weight 33 :P even with AD08s it just skates in 2nd sometimes the extra weight helps just squats the car down and grips.
Ofcourse we shall be doing this in a legal environment / on the strip :) but yea I'd imagine you'd have me on roll if dat power is legit
Edited by UNR33L
Gooby pls... I said brake boost.. he'll be on boost before you hit the loud pedal and your taxi just be a dot in his rearview mirror.
Gooby pls, propper 1/4 race from the line :)
My brothers got a GT35something in his, thing don't make boost until 6000rpm!
your brother isn't tony...
4500 - 8000k
you will lose - then be fined for fog lights
face it
Yeah what Hamish said. Im making full boost ~22psi at 4,500 rpm
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
