what if you enjoy what you do? :/
what I get done at work is far more productive that doing shit at home. its more leisurely, but dont get that feeling of having actually done something. Dalai Lama is right, but missed on the important factor of productivity. "back in the day" where people worked to survive or worked (harder than now) to keep family afloat, it was different but now... you can easily do nothing if you want. so productivity and sense of accomplishment are important factors.
Yeah that was just a random quote I got off google
It was more in reference to Ishan
I see too many friends with degrees, who go through all that work and end up either unemployed or just an ordinary job not related to their degree. And as such has been a waste.
So Ishan should work his butt off (doesn't have to be academically) to put himself in the best position possible to secure a full time job after he finished uni
The future; so scary.
But I do agree with points raised. Gotta make the most of this once-only life; career and lifestyle wise.
Human evolution
Sorta reminds me if this video I saw yesterday
https://www.facebook.com/photo.php?v=287437474738184
I agree. But that does assume you won't be productive with your spare time...
Also, productivity and a sense of accomplishment doesn't necessarily = happiness...though it may for some. A life enjoyed can be a matter of feeding the senses, non-stop, with enjoyable stimuli!
I think that everyone should try sitting on both sides of the leisure vs work debate and then decide. Work an overworked and highly paid job; be unemployed for 6 months. Preferably in that order. Then decide where the happy medium lies :thumbsup:
Anyone here work in the city? I could possibly be soon.. I hate getting the train from SE suburbs so would probably buy a place closer and do the whole move out of home thing.. Probably about time hey..
Docklands
Train from Brighton each day...
Easy as
Catching train from SE brah checkin in
I did the working like a dog, and being a bludger for 6 months.
Didn't like both. Must be my shitty job and lack of money to enjoy during the bludging.
So find the happy medium...it's seldom going to sit at either end of the scale...
With what I've got, impossible.
I'll just continue working cos extra cash is useful for moar beers.
St Kilda Rd. I drive because I get home quicker in the evening. Kinda over it though. 12 hour days with travel
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
