Teach her how to drive a man's car... like a manual micra
haha, she will have bambino in the car, so need something a little bigger! but i like your thinking! :woot:
if she could drive manual ive told her she can have the clubby..... shes thinking about it!
had my car over 2 years now, aus POS running fine with another 50% power than standard daily - love it
ITT: close minded import fanbois
grant I should aye :P
Edited by UNR33L
Do it!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
