security and can be breached with someone taking the card and paypassing anywhere.
hence the $100 limit on paypass
Ha! I took it for a quick spin down some roads the other night
Suprisingly i have lots of traction, full concentration is required tho once you boot it
Best way to describe the car compared to 280rwkw is
2nd gears feels like 1st gear
3rd gear feels like 2nd gear
haha about time.
you will get used to booting it soon and it will feel normal again.
get a diff asap though
haha about time.
Nah bugger that
Get a diff just as it starts to feel normal again, to maximise the novelty
For us about 20 atm, for the surrounding farms, hundreds to thousdands
yeah I understand that.
I'll talk to my dad tonight to see what happening with his.
they had an offer on their land, so they started getting rid of the cattle but it fell through so no idea if he has anything on it
wait for DECA... that shit is like an ice skating rink with 185 let alone 385
R34 has the torsen style, so a little better than the 32/33 diff. But still shit.
You will find on track it's very disconcerting (shitting pans style) to have the thing hook up sometimes and not other times.
especially in the s's at winton eh :P
Such hoon. Much Bogan. Ford.
:P.
I still haven't seen how quick this taxi of yours is, tho, real talk (torque).
hah, problem is peak hour you rarely can open her up
duno best I've done is a 11.61 1/4 mile, want an intercooler to try dat dere 10 tho
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
