Shouldn't be idling anywhere near that lol, you checked for air leaks around the throttles?
No air leaks. It's meant to have that paste crap around the throttle bodies to help them seal but when I 1st built the motor I didn't know what it was and cleaned it off.
just use loctite. she'll be right mate.
but yeah 1600rpm idle is like "my supercharger is causing my car to stall at sub 1200rpm" or "my cams are so lumpy that I purposefully didnt get my car tuned and I retarded the cam gears myself so it sounds super mean, but had to adjust the throttle cable to keep my car running"
I'm too lazy to fix. Plus it means you don't have to accelerate to take off and the car never stalls.
Bitches love it when I idle through the little streets with cafes n shit and you can hear it coming from a km away.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
