damn didnt even get to polish it :(
ahah im still a bit unsure if im 100% commited to sell
so if i pull the plug you may just get to :P
you do interior leather protection man?
can do....leather needs regular maintenance more than protection tho...needs them oils rubbed into its hide every coupla months to keep it sexy...
I didnt know GTRs come with leather? I know them uncommitted to sell feels too...want my car gone, dont want to sell it..the duality is killing me :/
i just need interior mainly leather protection
i have had the exterior done with ceramic pro 9H so thats all done :P
To be honest I wouldn't bother with protectant really, leather doesn't stain easy, unless you are a messy fella....just buy some good leather conditioner and apply a quick coat whenever you wash your car...
awesome!
thank you for that!
nah i keep cars very clean inside.. slight ocd lol
ill pick some up tomorrow! :D
yeah if you are clean don't stress too much... they will tell you leather protectant will repel liqiud etc...it will run off your seats..but then what ,its only going to run onto your carpet,..Its all sales pitch far as I'm concerned....the natural oils in conditoners will do much the same as long as they are applied regularly..
So I say why was their liquid on your seats in the first place... :P
but leather does definately need conditioners to keep it plush, otherwise it dries out and cracks...I've seen lots of lowish km euros with rooted leather cause owners don't condition it...
Haha....
you can sit on straight away of you have too ..
...might be a little slippery especially.on your steering wheel and gear knob...dont need to put it on thick though...light and often is better...and often is only like every month or 2....just learn to feel the softness in the leather and you will know if it's drying out...your drivers seat will dry out more quickly of course..
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
