I'm assuming it's more of a summer thing... does the work shrivel up in winter?
It revolves around wedding season funnily enough. Do get a few in winter though.
How much do you actually get for that shit birds?
60-75/h cash onsite, 100+ offsite
Come at me Ric
Come at me Ric
My area only deals with people worth $30m and up
So probably most of the vic wasteland actually
The first set of rims I bought for my 33 back in the day...I was moving them out to the driveway to fit....Mum offered to help, I said nah it's all good I've got it...she ignores and helps anyway...rolls one a few meters and drops it face down... Thanks Mum :thumbsup:
What's the job?
Just filled up the ute...$104 fuaarrrk
Reminded me of when I was selling my range rover wheels off the golf, went to get the tyres stripped at a local beaurepaires, guy managed to damage 3 rims on the tyre machine and one of them dropped face flat when was moving it to the machine, then had the nerve to ask for money for the work, even though the rims needed repainting
Need a job that I can work whilst at uni. Besides waiting.
Ideas?
Thought you were working at carwash?
Yeah it was. But they're f**king him around and stuff. Boss has deals with Wilson Security and few others now though, so that's made up for it. But that's just washing their cars.
Applied for aldi just then. Gonna spam a few more job ads.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
