nice! some good suggestions will be sure to check them out.
keen for a lot of their food places actually, want to check out Dennys
ah yeh that's good you got a mate with a bike trailer how hard is track riding? been thinking about it for a bit but would suck if I came off and binned my new bike lol
do you use laptop for work? should get like a toughbook or something and claim it on tax?
if not you can replace keyboards in about 5 minutes depending on the laptop too
Track riding isn't 'hard'... you just go at your own pace anyway.. Probably wouldn't be doing it on a 20k bike unless you're loaded, but I guess if you're going slow enough the risk is pretty low...
Only use it for work at home, so not like its on site etc.. Due for a new one anyway..
Nismo indicators, should I go clear or smoked? Body colour is black, so I'm thinking clear, but I can't decide.
Definitely smoked. clear will look aids on black
pretty sure my cousin sells them
http://jdmracing.com.au/
/shameless plug haha
smoked will give tuff look, clear will give clean look.
Edited by UNR33L
Yeah I was thinking same thing, probably better off buying a unregged 8 year old cbr1000 or something if I wanna get into it lol
Hows the experience compare to car track days?
So Red Bull Racing (and so Vettel etc) are (or were) at my Uni today.
Guess who was in a literature lecture...
really? would be awesome to meet riccardo i reckon - seems like the type of guy that would answer your questions and not get annoyed lol
gonna miss the f1 :( but i'll be in miami so I got that going for me which is nice.
Enjoying the company of other men?
He is/was here too, I'm told!
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
