mm. sounds easy!
I've never played golf cos I've no desire to play unless I get to drive golf cart.
My brothers know this and they don't ask me to play for that very reason...
Hey Alvin, I went back to Burwood one the other day to check out how the random GTR owner was washing his car. Turns out there's a car wash in the underground carpark, and he was using their water after hours, lol.
So basketball games are pretty awesome to watch, soo much off court entertainment and shit going on when they're not playing will have to see another before I leave here :D did you know they play all kinds of random music and shit to put the opposition off? Lol some guy Mario gets the ball and Mario bros song comes on /themoreyouknow
Also Miley-oke (karaoke) at half time provided many lols
Aus could learn a few things for their sports stuff.
Anyway brahs checking out of miami, bitch.
Edited by UNR33L
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
