Will you hold my hands on stage? ;-)
Nah, not night shift. Have a full time job, a second casual job and applying for engineering grad apps = sleep deprived and SAU procrastination plus wanting to go deca :-/
Anyone free next Tuesday or Wednesday and wanna help me pull my dash out so I can put some replacement LED bulbs in? I've never done anything like it, and I don't want to break anything. Also, does anyone know if a 34 is supposed to have a headlights on/door open/key still in ignition warning? Mine doesn't and I'd like to have one if I'm supposed to.
should not be overly difficult do a search on SAU for installing LEDs and follow instructions
Oic.
And yes, I'll hold your hands.
