Think it was like $150 for all four corners? Got it done at same time as all my poly bushes etc. so hard to tell. That was with Centreline too, so can prolly find cheaper at Traction Tyres?
I'm told it should be done anytime you make a height adjustment or major camber/toe change. Or lose/gain 20kg...
Nah, corner weighting is done pretty quick with the right equipment...it's basically a scales for a car placed at each corner and adjust the height of the coilover until the weight distribution is as even as possible. You never get 50/50 front to rear on a skyline but you can get pretty close side to side, which is what matters more.
My huge bill was from getting Centreline to replace every bush in the suspension with polyurethane, corner weight, install hicas lock bar and alignment/balance.
Probably not a bad bill considering, that's a fair whack of work and bushes are one of those jobs that are a pita without the right equip....
Does it involve ride height adjustments or mostly just dampner changes....Like if I had my car at a height I like would it come back a different height?
Even with the right equipment bushes are a flamin mongrel lol. I did it once on a car and never again. Centreline reckon they put 15 hours of labour into it...removing basically the whole undercarriage which is probably a legit estimate. Oh well, good thing about poly is you only have to do it once :)
It's ride height adjustment. You can tell them a certain height that you like it at and they can try to keep it, but in the end one of the sides will need to be raised or lowered relative to the other in order to redistribute weight...unless you nailed it straight up when you installed the coilovers lol. The reality is, that a car's weight isn't evenly distributed, so giving each coilover the same position and height at all four corners, although looks nice and even, will quite likely give you a shitty weight distribution.
50/50 weight distribution after corner weighting will likely have one side sitting slightly higher than the other. Usually the driver's side to account for your weight, but manufacturers sometimes build a car to be balanced with driver's weight included. Fair few variables to it.
Mine is crazy weird...i have about another inch tops that I can drop the front, the rear has about 3 nches more drop in it...that's with tyres sitting about 10mm from guards all around...so if I did them all even it would look very odd..
I did a couple turns more height on the right but nothing drastic...
So it's just height, they dont change dampening or tighten up your springs or anything...
Not that I'm aware of. How do you tighten up the springs?
Dampening shouldn't really affect weight distribution in terms of a static state, it will alter dynamics and ease of weight distribution / balance in a corner though. That may or may not have happened to me when I may or may not have put the fronts on hard and rear on soft at DECA...
A good suspension shop should be able to set you up with everything based on info you give them; track car, race at Sandown etc.
Just went to see Need for Speed with a mate, at Knox, in the Skyline...
Come out of Ozone and start walking towards my car, boom, highway patrol, boom, divvy van... Then in a random dark side street in Vermont (Mildara St for any Birds playing along at home) there were 3 marked cars just sitting there... some random domestic or something must have happened :/ But they were all standing around glaring at me as I cruised past, I honestly expected them to light up and follow :/
Good movie actually, it's a switch your brain off and enjoy the car porn movie :) And enjoy it we did :D So glad I saw it at the movies instead of downloading a dodgy screener version...
well the spring seats on mine are adjustable...I figure if you wound them up it would effectively change the preload on the spring...or sumtin :wacko:
Preload is how most coilovers are adjusted for height though...I wouldn't call that tightening, but you're technically correct if that's what you meant by it.
No..vehicle height is adjusted at the base of the coilover by winding the shock deeper Into the tube.....the base of the spring seat adjusts the preload on the spring...so if you want it stiffer spring you wind it up or "tighten" it...
Might be better in 3d but it's not fantastic...they are fast cars but just never really look like they are going fast....
I guess thats what happens when you dont use CGI
It is good entertainment though..quite alot of larfs early on actually
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
