anyone got one of those soniq tv's? probably getting one for the garage at home
not the best components i know.. but as long as it doesn't blow up i'm happy
$259 for a 40" (1080p LED) at jb is decent (last years model)
Kogan. 40 inch LED $299.
Had one, sister has it now, still works fine. Colour etc is pretty crap though, always looked mega washed out. I looked at a 55" when I bought my current tv but still looked pretty washed out. Much happier with my 50" Samsung for only slightly more coin.
Hopefully should be OK man.
Bought a few things with some mates awhile ago, when the package arrived my shoes were actually missing (no apparent reason, but could see in the picking slip it looked like whoever was collecting all the items just forgot or something -___-''), which was pretty annoying. But gave them a call / email and it was sorted out relatively quickly iirc. Still disappointing, but wasn't the end of the world; was sorted relatively hassle free.
They weren't missed they must have went out of stock between me placing the order and them processing it... Every other item on the list says sent bar one pair which says cancelled, and the order status says partially cancelled.
I know I'll get a refund but common sense would say email the buyer and ask if they want to choose another pair... Or at the very least, email them and let them know they'll be refunded etc
Tariquet... You can do better than that :P
grab yourself a 1979 Comte De Lamaestre (have to buy it online as the sole importer doesn't have a retail liquor license and can only sell to restaurants)
Don't disagree with you there.
I will take a look
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
