anyone got one of those soniq tv's? probably getting one for the garage at home
not the best components i know.. but as long as it doesn't blow up i'm happy
$259 for a 40" (1080p LED) at jb is decent (last years model)
Kogan. 40 inch LED $299.
Had one, sister has it now, still works fine. Colour etc is pretty crap though, always looked mega washed out. I looked at a 55" when I bought my current tv but still looked pretty washed out. Much happier with my 50" Samsung for only slightly more coin.
Hopefully should be OK man.
Bought a few things with some mates awhile ago, when the package arrived my shoes were actually missing (no apparent reason, but could see in the picking slip it looked like whoever was collecting all the items just forgot or something -___-''), which was pretty annoying. But gave them a call / email and it was sorted out relatively quickly iirc. Still disappointing, but wasn't the end of the world; was sorted relatively hassle free.
They weren't missed they must have went out of stock between me placing the order and them processing it... Every other item on the list says sent bar one pair which says cancelled, and the order status says partially cancelled.
I know I'll get a refund but common sense would say email the buyer and ask if they want to choose another pair... Or at the very least, email them and let them know they'll be refunded etc
Tariquet... You can do better than that :P
grab yourself a 1979 Comte De Lamaestre (have to buy it online as the sole importer doesn't have a retail liquor license and can only sell to restaurants)
Don't disagree with you there.
I will take a look
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
