Bucks Party today, around the Sunshine Coast area...
Us niggas gon be rollin in a tarago, baws...
BBQ Lunch, Go Karting, Rock Climbing, Laser Tag, Pub Dinner, while getting progressively more and more drunk.
We ain't allowed no strippers :( And have to make sure he doesn't get damaged because the wedding is on Sunday :( Booo
but the speed limit is 100kmph Leigh...so driving that thing on the street would be horrible...
speaking of horrible things to drive, now that it's wet + my rear NT05s are basically bald = slipping all over the place :(
might get some nitto invos or something for the rear only.. argh cbf spending the cash. NT05s lasted just over a year hah
Edited by UNR33L
haha that's what i figured. i'm unaware (only care about sti's [inb4 std jokes] :P), did the earlier models come in auto too? wrx's iirc relatively affordable, right? and a bit of punch!
mate has an my06 that i drove, never not on boost and making sounds LOL dat smaller turbo. was manual though.
I was launching the evo in the rain last night
where's your 370 kw now bitch?
ehh rwd more fun!
I seem to recall some bloke telling me to drop my shaft in GTR and drive a 'mans' car :P
Birds saw you turn left onto FTG road this morning was at lights waiting to turn right. /csb
Edited by UNR33L
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
