this. fit some extractors too? complete the v8 sound package.
you been hunting for a new compressor Nick? keen for some eventual air horn action.
but he seems like a teeneager. cant wait more than 5 mins and to lazy to do any leg work.
prob expects us to get out there and do it for him.
i already told you. 2-250 is price for a front bar. anymore and they are touching your ring piece.
oh look, 30 seconds of googling.
http://www.gumtree.com.au/s-ad/broadmeadows/other-parts-accessories/skyline-r34-front-bumper-genuine-/1044047746
  • Like 1
Found a picture of OP
80403cff562472f5363e4d5b42a17a58-leg-day
Got told $350 for a bar and $260 for reo. today. Yay or nay?
yes I am serious.....dude i sent you PM...will fix and respray your bar for 200, good as new..... ;)
for another 200 I will paint correct and detail your whole car...for 600 I will do naughty unspeakable things to it...
yeah and still needs to be resprayed...thats another 200 at least...so 400$. +...
anyway i have seen pics of the dent and the reo is fine...just needs some filler and paint will be good as gold...I'm also bored so need work :P
still on for friday!?!? like farkin 9am!? got friday and sat to get everything out cleaner is coming sunday.
well that depends...if bucket boy is going to pay me 200$ to fix his bumper, i may be busy :P
unless you want to match it :rofl:
if your under 30 your opionion doesnt matter.
well it does to you but what you don't realise yet is nobody else GAF.....once you hit 30 everybody listens to you no matter how stupid you are.this I know from experience...however i'm guessing the rest but I think when you reach 40 and you just wish everybody f**k off because the kids have driven you beyond driven...then at 50 you wish they would come back...by 60 you realize its not going to happen and you retreat into your lonely old crazy self but everyone respects your wisdom because of your age.
And thats when the fun begins... :devil:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
