not to mention... a chef worth his salt will buy entire cuts and break them down himself which means he has a wide variety of choices to give you
take a ribeye for example.
so you clean up the whole thing and portion it. as the you go along the rib the steaks get progressively tougher and leaner.
so what happens is the shitty fat free tough as old boots ones get put in their own special pile for well done steaks and rude customer (or those that come in at close) then the chef has his little collections of the remainder with varying marbling, sinews etc.
you order the correct doneness and he will get one of the better ones.
you tell the waiter to "just let the chef cook it" they will go straight to the "piece de resistance"
Because ultimately, "rare" is subjective.
The guy doesn't know you, he only knows the 99% of other people that have come through and asked for "rare"
The only way you could ever really get it right, is if you go to a place and either
a) Luck out
b) go there enough times that you know what a baseline is for how they cook their meat
Same applies to "spicy" too
easy. bring me a steak. make it rare.
simple. could be f**king 4 inch thick or half inch. i want it rare. simple as fark.
every other flamin mongrel in the world at top restaurants can do it. why is it so hard in australia.
because a rare ribeye / scotch fillet for example is pure shit. it has fat that hasn't broken down and tastes like ass
a rare eye fillet is great on the other hand
a) Luck out
It's really not. See chart below
Sure there are in betweens, but you're not gonna whinge about a shade lighter or darker as long as it's closer to what you want.
should have been more specific there.
f**kING RARE.
I DONT GIVE A SHIT WHAT YOU THINK.
f**kING RARE.
chicken pork beef snail horse pigeon rabbit human.
rare. because thats what i asked for. and because your job is to cook food for me how i ask for it.
(i seem to have some hang ups about the quality of chef in this country hamish, this in way states i think your shite, im sure your a lovely chef, and that you trained at the fluer del loo de laeeuriruf french word and you meat is magnificent)
however of the 100 plus steaks ive eaten in this country about 2 have been cooked rare... and most have been shite. sure 90% of these restraunts where not "hipster class" but still give the people what they ask for man.
rant over.
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
