if you're talkin about post count I can't see anything cuz I use the phone app dude.
Really don't care bout post count anyways - it means nothing except demonstrate you can post a lot on a public forum ........whoopty f*ken do
just dont tell Luke that ok...it would ruin his world...
reading the vipec manual for evo 8 plugin for some pre-reading
IAT Through Fuel Temperature Pin – Pin 77 is connected to An Temp 3. On some models this is
used to measure fuel tank temperature. You can wire an IAT sensor between this pin and pin 92
(sensor ground). Refer to Appendix B for pin numbering. Additional terminals to fit the factory header
are supplied with the ECU.
sif the evo 8 has fuel temp sensor ????
