Speaking of which rules changes will mean not much LAFHA anymore
my understanding of the changes means some companies using it as a tax dodge will be decreasing it. people like us who use it honestly and get reamed by the ATO anyway will continue using it as intended.
when I was claiming kms, meal allowances and LAHA my untaxed income was high which was punishing. why not just tax it all because its going to be taxed from me regardless.
listening to ABC radio today (only thing in reception) and it makes me angry that ABC spends all day interviewing and reporting on academics and political figures to talk about politics all day, all of who are basically in the public sector. everyone talking about what should be done, but nothing actually getting done. and no ad revenue means its 100% funded by the government. all the crap they were reporting and discussing could be summed up in a 60min program.
how about lets abolish ABC2, ABC3, ABC24 and ABC classical radio and broadcast important programs on commercial stations for providing unbiased *cough* national information. would it not be much cheaper and more efficient that way?
tl;dr: people paid by the government interviewing people in the government, talking about how to improve the government, broadcasted to those who pay for the government and/or are paid by the government.
  • Like 1
Some of the changes:
1. You need to maintain an 'ownership interest in a unit of accommodation in Australia - not rented
2. Substantiation of all expenses
So unless you 'own' a property your going to have a bad time. And by bad time I mean your employer
free tax advice to offset your soldering work
  • Like 1
its also limited to a twelve month period unless FIFO employee
Hai guys, CBF joining civic forum but anyone have expereince with EK civics and rims? Looking at buying some rims for the missus's EK Civic, probably either 15s or 16s. Not looking for poke or anything, just something that sits tight without tyre stretch and headaches like camber.
I have an EK civic as a daily
Know nothing about them tho :P
not everyone has the opportunity to shop at duty free on weekly basis
Even some duty free outlets are rather exy
Yes melb is shocking Dubai not much better
Singapore one if the best.
Cheapest found surprisingly is Johannesburg but not worth the trip just for booze
Have been quoted $10k to supercharge my SS-V or $10k to single turbo it. Thoughts? :(
dude you are stanced on 245s, with either SC or turbo it is going to be the worst thing to drive...lol....SC will probably be worse on the street cause too much torque it will just light up tyres everywhere...i guess at least the turbo will give you some warning and time to catch it, before it launched you into oblivion...
My mate has a built LS7? , its a 7lt supercharged monaro.. he took the SC off cause it was just too ridiculous to drive... :rofl:
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
