richo when he had about 220ish RWKW did around 25-30 track days plus a years worth of driving on some AD08's so yeah they cost more...but they also last more.
If I remember right ash had some A048 or A050's on his GTR street driven when first got it, lasted about 5000km
So redoing my security clearance at work..
List all Overseas travel in past 10 years..
FML
hehhehe. i feel your pain. American government do not like the fact im british working for aussies on amercian tech.
if i was arab im pretty sure they would bomb the building.
FML
Will take you all of 5 minutes copying from your passports
In that time 45 people will contract HIV, 15 people will be the victim of violent crime in America alone and 500 people will die including
100 from starvation, predominantly children...
But yes... f**k your life... Princess
  • Like 1
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
