I am kinda operating on the theory that to prove the the work in question was actually carried out, you would require invoices/tax records that are now of sufficient age not require retention.
that and most work in that industry is cash and may have in fact never occurred... i was simply doing it for the love of it ;)
Yeah as if you got paid just to push play trolololol
Toby, can I claim my $815 graphics card upgrade?
Also, watercooling I'm guessing is a no no?
Tax time were everyone is suddenly your best mate
Depreciate it, in accordance with your work use percentage
Disclaimer: Not taking anymore tax questions
  • Like 2
Lol my parents are both accountants, they get so many friends who want to "catch up for dinner" when tax time comes around...
They show up with a bottle of wine and folders of paperwork
  • Like 1
that is LOW
Oh so that's what your parents do? I did not know this. Or maybe I did and forgot lol.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
