Just calculating my fuel consumption today, tried to granny this tank full:
Kilometers traveled: 383.
Fuel used (BP98): 53.38L
L/100km = 13.25
Could easily get 400km if I hadn't gone to King lake and booted it a few times.
Not too bad I suppose, for a 270rwkw car.
Mines pre similar to that
  • Like 1
so jsut saw/heard my first alfa 4c..
Never had some much want for a car.
squat aggressive, rear looks like a ferrari, front like an alfa and side a cross between a 35gtr and a elise.
and sounds like a big capacity motorbike.
They are beautiful. I've wanted one for a couple years now, but always concerned about fitting in one as these cars don't usually favour the tall with head room or accommodate long legs :(
That and dumping 80k on a toy, I'd wanna be sure it was slightly comfortable enough to daily.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
