I got some Invicta watch when I was in the U.S, only really wear it when I go out or want to look professional, cbf most days at work been here long enough to not care
Toby I didn't realize (or think of it I guess) I could claim office chairs on tax #themoreyouknow
Edited by UNR33L
chrome and that kit :yucky:
plattsy, GTiR brakes are an expensive way of saying N15SSS brakes :P
AD22VF's also came on the NX coupe, so theyre around. write-up: http://www.pulsar.org.au/tech_ad22vf.php
cheers mate.
qdb1281 is the a1rm... sweeeeet.
cheers mate.
yeah theyre good pads. Jason gets them at a decent price.
been a fairly "mild" winter at Eildon so far, but today is proper chilly. reckon there will be some decent snow the next couple of days.
Im planning the family tobogganing day trip. anyone vouch for Lake Mountain or Mt Baw Baw? I've been to both but many moons ago and dont remember having to pay for entry up the mountain...
yea ill hit jase up when i get some kesh, hes getting my braided lines for me.
what brakes you running?
i got N15SSS rears and R32GTR fronts running A1RMS.
reminds me I need to bleed the lines.... but priority is to get the engine checked up. but that requires a day off. and a trailer.
gtr fronts?!?! wut!
so 33 gtst brakes.... you have to get you rotors drilled then i take it?!
shit the micra would do endo's with the 4 pot sumitomos.
its complicated...
older nissan small car hubs have some unique bracket size that only allow for swapping with other older nissan small cars.
N16 pulsar has a more common size, allowing FTO, maxima, skyline, silvia calipers etc. R32GTR sumitomo is the best for size/pad surface area/wheel availability for clearance. GTST are cast calipers and smaller pad but also 4 pot. brembo GTRs are bulkier and require spacers to fit im pretty sure. but if rolling in $$$ could get some aftermarket calipers.
N16 hubs machined and re-drilled to desired PCD, fit N16 bearings.
R32GTR calipers with N16 hub will take 288mm rotors, which means purchasing 300mm and machining down (not a fun job). then usually need rotors re-drilled too.
its complicated...
Gtst calipers are alloy, Silvia calipers are cast
Cast they are the same as Silvia calipers
This
you sure..... they all look alike to me.
plus literally everything on the wrx is alloy. EVERYTHING.
Definately, why they decided to go with the budget spec caliper I do not know.
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
