I got some Invicta watch when I was in the U.S, only really wear it when I go out or want to look professional, cbf most days at work been here long enough to not care
Toby I didn't realize (or think of it I guess) I could claim office chairs on tax #themoreyouknow
Edited by UNR33L
chrome and that kit :yucky:
plattsy, GTiR brakes are an expensive way of saying N15SSS brakes :P
AD22VF's also came on the NX coupe, so theyre around. write-up: http://www.pulsar.org.au/tech_ad22vf.php
cheers mate.
qdb1281 is the a1rm... sweeeeet.
cheers mate.
yeah theyre good pads. Jason gets them at a decent price.
been a fairly "mild" winter at Eildon so far, but today is proper chilly. reckon there will be some decent snow the next couple of days.
Im planning the family tobogganing day trip. anyone vouch for Lake Mountain or Mt Baw Baw? I've been to both but many moons ago and dont remember having to pay for entry up the mountain...
yea ill hit jase up when i get some kesh, hes getting my braided lines for me.
what brakes you running?
i got N15SSS rears and R32GTR fronts running A1RMS.
reminds me I need to bleed the lines.... but priority is to get the engine checked up. but that requires a day off. and a trailer.
gtr fronts?!?! wut!
so 33 gtst brakes.... you have to get you rotors drilled then i take it?!
shit the micra would do endo's with the 4 pot sumitomos.
its complicated...
older nissan small car hubs have some unique bracket size that only allow for swapping with other older nissan small cars.
N16 pulsar has a more common size, allowing FTO, maxima, skyline, silvia calipers etc. R32GTR sumitomo is the best for size/pad surface area/wheel availability for clearance. GTST are cast calipers and smaller pad but also 4 pot. brembo GTRs are bulkier and require spacers to fit im pretty sure. but if rolling in $$$ could get some aftermarket calipers.
N16 hubs machined and re-drilled to desired PCD, fit N16 bearings.
R32GTR calipers with N16 hub will take 288mm rotors, which means purchasing 300mm and machining down (not a fun job). then usually need rotors re-drilled too.
its complicated...
Gtst calipers are alloy, Silvia calipers are cast
Cast they are the same as Silvia calipers
This
you sure..... they all look alike to me.
plus literally everything on the wrx is alloy. EVERYTHING.
Definately, why they decided to go with the budget spec caliper I do not know.
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
