This is the core of the issue... You don't think it's worth $80/hour to do, however for a skilled machinist in a shop dedicated to tasks like this it is...
They've got to pay Wages, overheads, Rent, Cost of Equipment and Consumables, Superannuation, Taxes, Power, Gas, Advertising and a skinny philo called mikeymike to sweep the floors. They're a business, if that can make a small profit after that they're doing well.
This is why I DIY as many things as I can, only going to specialists if its something that I can't (or it isn't cost effective for me) learn to do myself using my own tools.
Heart bleeds for small businesses
Denies them work
  • Like 3
Sometimes I miss my old VL. Steering racks leaking, buckling wheels/panhard rods from drifting into gutters on rainy winter days. Filling the boot with bricks to give more lows. Freeze plugs rupturing coolant into my driveway.
I need to buy another 80's shit heap to keep me occupied. What I would do for an old Honda City turbo.
guy back home had a little Honda city, thing was a monster smashing V8's all over the place.
dude was an ex gibson motorsport mechanic tho.
also had a VL calais, with full R32 GTR drivetrain awd and all, with some tasty gibson GTR upgrades to it. all this back in mid 90's
  • Like 1
Lol you're probably paying them to do what you are about to do youself..
Doesn't matter what they tell you they're doing
a file and sandpaper wheel on a drill....I suggested that already, but those tools alone will cost your 20$ of you buy cheap shit, ypu might get lucky and they wont break and do they job, or you may not and then spend more ...or for 80$ if you might buy good ones..and after all this you still may not be able to do it and crack the shits and finally pay someone else to do it and it just ended up costing you more than it could of...
been there,, done that,, will probably do it again too...
Ahhh, the legendary all wheel drive vl. Last time I saw this was on car sales afew years ago for a silly amount, something like 80 grand
which one? he apparently made 3
his was the silver, there was a pink one roaming around echuca I think and a 3rd up north blue off the top of my head
  • Like 1
needs more T67
hey hamish, your pretty tall
did you have to adjust your seating position or how you use the pedals in your evo?
am i retard? i swear its as if im almost clutch slipping sometimes when i grandma change gears
doing it quick its fine, but normal speed shifting it almost free rev's a touch when coming off clutch
i dont think its clutch slip as it handles full load on full noise no problems
am i being a retard????
My mate just bought a VL Calais turbo.. Genuine 180,000kms 100% original... I still don't see the point but each to their own I guess
100% do not see it.
Looks like a bag of dicks
Drives like a bag of dicks
Costs a fortune
Horrible, ugly, shit cars
saw that silver one in street machine...probably still have mag somewhere, was awesome
and thats back when you couldnt find a wrecked out gtr for 5k...
needs more T67
Seating position I lowered with brackets that bolt onto the stock rails. Now i see why you were saying you couldn't see the speedo, it's cos you have the stock seating position.
Stock seat height in evo's is TERRIBLE... It might as well be mounted on the roof for how high you are. Brackets will drop you close to 2"
Clutch wise, who knows... I have an HKS single plate so it's either on or off lol
yeah thanks, it kinda makes sense - ive got stock seats and std seat positon
i dont feel that the seating position is too high (at least, it seems OK)
but i swear, its as if i dont take my foot of the accel pedal enough (or properly) so its ever so slighty during gearchange, which makes it almost free-rev after clutch in/out
ill do a drive on saturday and log it and see what the logs show, it should show TPS not dropping to 0.30v if my thinking is correct on gearchange
very odd
is there a company who makes the brackets or did you do it yourself?
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
