Do you miss your balls? What did they do with them after they got cut off? Did you get to keep them in a little jar?
Naw mang auto is faster and way better gearbox in general
If I want my balls back I go on my 'manual' motorcycle!
So all these new smart watches, good or gay?
http://www.news.com.au/technology/set-solutions-video-shows-vision-of-apple-iwatch/story-e6frfrnr-1226977391317
functionality looks alright, but can't see myself wearing one of those
I'd punch any tech hipster wearing that in the dick, fo sho.
Birds will backhand him while wearing his pretty watch, as long as it will inflict pain.
Any chance to touch another mans penis right?
Current Android ones are pretty gimmicky and useless, will be interesting to see what the iWatch does though (don't think I'll be picking one up either way).
If it's like other apple products expect it to have half the functionality of the android versions until the 5th or 6th release which will be behind in other areas instead :P
What Apple products are lagging behind?
without getting into the usual "apple vs everything cos they're the best even tho ive never used anything other than this shitty iphone" debate,
i just jumped ship from iphone 5/5s to galaxy s5 as one. you cant compete. s5 every time. battery life expandalbe memory, a camera that is actually good. etc etc. iphone is so far behind it isnt funny.
It depends what you're after. Most people consider the iPhone 5S camera to be superior to the Galaxy S5, not to mention other hardware features like a much better fingerprint sensor, better build quality and no bloatware on the OS.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
