Alvin, I have seen a lot of people eat scotch fillets bleu. The best part is the people that order bleu always have to make a big deal about it and ensure everyone knows.
Then when they get their meal and realise just how bad a bleu scotch is, there is no way they will ask for it to be cooked more. And they are very aware of the whole kitchen laughing at them
lol need to rephrase then.
see people order and enjoy scotch fillets bleu.
hey Aayron, who did you hire your jetski from?
what sort of price?
an no Moh I don;t want to buy one, just rent for a bit..
The adrenaline place on the island.
Solo:FJ$538
Tandem:FJ$575 (that is FJD287.50 p/person)
Go quard biking though. Cheap and I would do it over and over again.. and ask them to take out the Baja..
http://www.fiji.travel/activity/go-trek-quad-tours
Personally the best thing I did there..
i'm sure everything is a defectable offence man. probably should just go commit some real crimes, maybe deal drugs or something. they dont get hassled as much apparently.
And they make good money rather than get money taken for no arbitrary reason...
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
