worldly VWLers: gf needs a luggage/suitcase for Japan trip.
wants something lightweight and I have no idea.
any brands to recommend or styles?
Gucci, Prada, it's all good
No one compares to this guy, and I have the pleasure of sitting directly opposite him in the sheds... He'll tell the most pointless stories that go on forever, and end up nowhere. Today he told me that a BMW engine from 30 years ago had 4 throttle bodies....
Good thanks Ric, how are you? I'm sure you're looking forward to the release of Monica's new album Year of the wolf, and The Documentary 2 early next year
Do you read your facebook statuses before you post them...?
My mate seems pretty happy with his A6
theres a fine line between raging anc complaining, luv.
how are you anyway?
I got a samsonite whilst in Thailand
Good quality and weighs like udner 1kg
Might be exy over here though
whos going to the members cruise tomorrow?
If you could tell Vu to fix my car today ill come along
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
