what helmet you have now?
bell.
unfortunately, it has a british standard and tuv test sticker. but no adr....
same with my bike helmets.
ill go get a cheap $50 dollar job from the shop on the gippsland highway...
check with WRX, as most clubs allow the British standard and snell the USA one on the track.
we would pass them at deca as well when doing scruit
not so for motorbikes on the road.
EDIT:
WRX accept Sched D CAms regs
http://www.wrx.com.au/resources/Documents/Motorsport/2014/2014%20Round%208%20Sandown%20Supp%20Regs.pdf
and cams level for speed is Spec B check 3.1 they accept British standard's
http://docs.cams.com.au/Manual/GeneralRequirements/GQ05-Schedule-D-2014-1.pdf
Might become official FIFO for a while. Got a small project at a mine out of brisbane.
Probably at some dump like Gympie or Gladstone. Finally get to knock up some underage sheila, get a jetski then a mortgage (in that order). Living the dream.
  • Like 1
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
