https://m.facebook.com/profile.php?id=100004506918385&fref=ts
Pretty sad reading all that; why would a guy do that to his family and friends
What are we reading?
Also for someone that doesn't have facebook you sure know alot that going on in it :P
Also curious where his accomplices are at this time...no doubt has them as friends on Facebook and there are a few motorcyclists in his friends list. I could take a judgemental guess based on display pics, but that would be...judgemental.
The plot thickens..
Next step: go to funeral. Make sure everyone sees you ride in on loud motorbike. Keep tire iron hidden in leather jacket. Then time to get judgemental.
"Judgement Day"
Funeral action scene ensues, may or may not include mini gun inside the coffin.
3am on the morning i fly out, boss says need you at leongatha for 2 weeks, can you go there on monday but first swing by Bald Hills wind farm near Ballarat on your way.
So much for R&R.
That calls for christmas bonus. Hope i still get a chance to rego the gloria, fark having to reschedule with vicroads before christmas
is Huy electrical engineer? one of my contacts put this up yesterday: "Urgent - Seeking a Electrical Graduate Engineer for 6-8 weeks worth of work in Brisbane doing take off's for an Electrical Contractor based in Brisbane - Start ASAP | Please call 0408 138 011"
Interesting the day the bike was stolen she posts a photo of her wearing a motorbike helmet.
Yes I noticed this
I keep forgetting the date it was stolen and focusing on the date it was found
Mechanical...if it bleeds, he can fix it
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
