no i was hanging out of a chefs missis while he was making soup.
A chef's Mrs is generally his hand... so.... yeh...
don't you have that with bus ticket?
What's a bus... I take the train... busses are so 2013
  • Like 1
seriously thinking about a GC8 though... only real issue other than the glass gearbox is being cop bait right?
edit: and changing plugs
to be fair, takes about the same amount of time as an rb25.
glass box is fine upto about aw220kw. even then if you dont 8k clutch dump or flat shift to second they are fine.
no issue with piglets either.. but i have dadwagon.
N15 SSS
I said match, not escalate into uncharted realms of phaggotry
10-15 mins? that's not so bad
also wouldn't be looking to mod it too far past 200 anyway as would be trying to look stock
also wouldn't be looking to mod it to far past 200 anyway as would be trying to look stock
yea takes me 20-30 mins depends on beers in me.
exhaust, and power fc tune will net you a decent gain. turbo, injectors and ethanol will be plenty.
grants will have about 180kw atw when he comes to sell it... nismo sidefeeds and e85 tune will jump 200 easy.
prices have jumped cos nsw and others have it on p plate list. they are selling for 10k and up in nsw now. for early shite models. crazy.
99/00 model is way to go.
N15 SSS
Beat me too it.
Missurs dad is looking to upgrade 135i convertible to A45 AMG... I said to him servicing and repair costs will make the 135i seem reasonable. But if he gets one (and he probs will) i said ill rolling start drag him in the pulsar (sometime in the near future). He seemed confident.
I keep running into a red one that appears to be riced up too...SXYAMG or something like that...he wants to go me in a rolling but it's always in traffic on the way home :(
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
