"hi, i have a bench top meat slicer i want to sell"
how old and what make?
"dunno"
can you send us some pictures of it?
"nah my phone doesnt have any credit, i can bring it past"
no thanks.
Toby if I'm renting out a room to a mate, should I just get cash off him for tax purposes or is direct deposit into my account okay? does it make any difference come tax time?
Birds - when you get the GTR brah?
Edited by UNR33L
whats the price of 91 atm?
when I left it was 1:13 so I would expect E85 to be sub 1$ by now...When ti was first out it was advertises at 25c less than 91..what happened?
julia guilard/tony abbott
I has it
Same thing that happened with LPG I imagine. More people use, more demand = can afford to push up the price. They would have made it cheap as shit to get people using it and now they have a decent customer base, someone has to pay for all the new pumps.
But 98 used to be 10 cents a litre more than 91, and the difference keeps going up. So as long as E85 stays lower than 98, proportionate to the extra fuel usage, I'm happy. Even if a little more expensive to run it's worth it.
United recently took over a servo 2km down the road from my house and put an E85 pump in - so handy! Used to have to fill up 3km away from my work.
Filled up the excel the other day, think 91 was like 1.09 at safeway petrol... Seems to have dropped a fair bit since I went to Thailand, then again I don't really look at the price when filling up so maybe I just didn't notice it
lpg is not the best example, it has stayed similar 50-60 c jsut when fuel prices when up it became less economical. and now prices dropping it's dropping at same rate.
expected the same for E85.
considering how much more you go though bet there not many of those flex fuel commodores using it atm.
EDIT:
just went and checked Holden site, seems for VF they dropped E85 support, so guess that answers that one,.
EDIT:
I disagree on the LPG, it may be proportional but back a few years ago during the LPG boom when every man and his dog were doing conversions for $500, the price of the stuff jumped up with little to no change to petrol prices. I was filling up at 40 cents a litre or less and out of nowhere the shit skyrocketed...I put it down to demand.
demand will always bump prices agreed.
not sure the demand is there for E85 tho, not a huge amount of cars running it.
other than the FE commo, who supports it from factory?
also with prices going up makes you wonder how long it sitting in tanks for.
Don't get me wrong, I'm not against E85, when I get around to changing injectors will be moving to it.
just thought it was cheaper is all.
Must be the aftermarket using it - that or united are seriously committed to marketing it, because they keep popping up new servos with E85 / installing tanks.
Alvin may like to correct me, but I don't think e85 goes off / loses it's octane in tanks as fast as say 98 would.
They would be sealed to prevent water build up, and alcohol/ethanol doesn't really go off over time?
(in some cases improves!)
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
