Labors was way more juicy. For extra lols they brought back the guy they axed in the first place
Abbott might not be ideal but the public need to wake up to the need for budget cuts or we gonna end up like Greece. Heck Id take a labor gov provided they take some action to reverse the debt trend - but we know that'll never happen they are like women - spenders
Something something Turnbull likely.. something something fighter jets. Who's asleep?
This is the problem with younger generations they don't actually see the importance of who and how the country is run..
I blame the education system.
wtb evo x
Marry Toby.
^^ wasn't pickin on ya man just a generic statement and it's sadly quite accurate young people have no idea about politics God half of them think when the government pays its like its the governments own money as if it's a income generating business not the people's money
If Turnbull gets back in it's practically the same scenario... remember he WAS pushed out by Abbot. Albeit in opposition but it's errily similar.
What really f**ks me off is that at half a mill a year we will most likely be paying for 4 pm's that either weren't voted in or were ditched. That's $2m a year for life for a bunch of flogs that couldn't lead their way out of a wet paper bag.
Also you do realise that the whole budget surplus thing is not actually as important as it is made out to be by the LNP right? It's mostly just their current election strategy. Sure it's preferable but all it really means is our projected spend is less than our projected income. Even surplus budgets when actioned can still leave the country in debt and often do not actually result in cessation of borrowing, (especially when we buy EXTRA shiny fighter jets)
What really matters is that we see infrastructure projects implemented, economic growth driven and those that need it helped while working towards a balanced budget in the future (when the economy is better positioned.)
There is NO need to have it sorted by 2018, other than for the purposes of re-election.
What we need is a very centre right government. Unfortunately that is just not an option at ptesent.
so went to refuel car on freeway.
fire brigrade blocking road.
seems some tourists in their rental van put diesel in instead of petrol, so on exit to station at freeway,
just out and think lets drain the tank that will fix it, 100 Litres of diesel all over the road...
van still stranded on on-ramp to freeway as well.
The jets thing is a lefty go to option to pick on libs the fact is they were allocated for like a decade ago.. And national security isn't a bad idea imo.
you can't deny we are living in the age of entitlement and welfare and its completely unsustainable in its present state and set to only worsen.
budget may not need fixing in the next two years but action needs taking now not when we are further down the drain with no way out
The jets were budgeted for years ago and both parties were committed... but then we went and ordered 58 more.... it's a LOT of money that could have been better appropriated.
Yes it's an age of entitlement, no one can doubt that, but we need to have welfare, it's simply not avoidable
I agree we need to look into fixing the budget, but the approach has been deplorable and has also all but guaranteed a Labor government will return very shortly.
Australia is doomed anyways.
Iron ore has dropped to $60/tonne from $180/tonne highs
http://www.dailyreckoning.com.au/category/resources/metals-minerals/iron-ore-1/
Once a $30billion revenue stream for Australia has been wiped.
Buckle up, it's going to be a bumpy ride.
The policy's to fix the budget have t been that bad.. Students should pay interest on hecs loans the loop holes and outstanding balance is ridiculous
Paying $7 to see a doctor? No problem with that either
Despite what labor and the greens want us to believe there simply isn't enough rich people / corporations to slug more taxes on to cover the bill. Middle & low income will always feel the pinch as they are the most dependent and largest tax base and as much as they whinge figures showed after rebates / deductions they were taking out more than they put in...
ok this is getting out of control..
think we should put him down for his own good:
Mohsen Younes
snapped the lower control arm mount off the subframe, am I better off going gtr subby or having the standard one reinforced?
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
