You laugh now, but when I'm at a formal occasion with a shitty DJ and they need someone to drop Dre beats...I have something up my sleeve.
You probably tell that one to everyone who asks...
  • Like 1
Is there some sort of liquid in the tin when you take the spam out? Cos if so you could actually make a spam reduction
Surprised you have not tried it before
There is some sort of jelly that is slightly watery
Spam itself is oiled enough that you don't need a non stick or oil to cook it
Yup. Drop the wages. That'll make people want to work in the middle of a 50 degree desert
Problem is that people have built a lifestyle around the income & any pay is better than 0 pay.
Lot of small cap miners have gone into care & maintenance mode so there are a lot of people looking for any work.
I've been told I'll be changing to 8/6 roster from my 9/5 roster. Will be losing $20,000+
If my Maths serves me well then you're currently...
156-157k pa?
VWLBC leader
156-157k pa?
VWLBC leader
$20k is what hr has told in general for everyone in the office. No idea what it means for me. Could be more, could be less :P
Also your estimate would be excluding superannuation & bonus
I think you've told me before actually but I forget...
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
