You laugh now, but when I'm at a formal occasion with a shitty DJ and they need someone to drop Dre beats...I have something up my sleeve.
You probably tell that one to everyone who asks...
  • Like 1
Is there some sort of liquid in the tin when you take the spam out? Cos if so you could actually make a spam reduction
Surprised you have not tried it before
There is some sort of jelly that is slightly watery
Spam itself is oiled enough that you don't need a non stick or oil to cook it
Yup. Drop the wages. That'll make people want to work in the middle of a 50 degree desert
Problem is that people have built a lifestyle around the income & any pay is better than 0 pay.
Lot of small cap miners have gone into care & maintenance mode so there are a lot of people looking for any work.
I've been told I'll be changing to 8/6 roster from my 9/5 roster. Will be losing $20,000+
If my Maths serves me well then you're currently...
156-157k pa?
VWLBC leader
156-157k pa?
VWLBC leader
$20k is what hr has told in general for everyone in the office. No idea what it means for me. Could be more, could be less :P
Also your estimate would be excluding superannuation & bonus
I think you've told me before actually but I forget...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
