Also veggies are awesome when done properly.
Think back to Mt Buller cruise #3 where I had everone eating Brussel Sprouts and loving them.
so everyone was eating hamishes sprouts.
hamish,
can you please copy pasta your burger recipe? i remember the pure beef mince part (have found decent mince) just need advice on buns, and method using glad wrap (ive forgotten)
  • Like 1
Smashed some Vegan Pizza last night, it was too good for my liking... I even fried up some seasoned tofu strips, and they were eaten before they made it to the pizza, like they were Haloumi.
I don't know what is happening to me, everything I've always thought about vegan food is being disproved :(
  • Like 1
hamish,
I'm not allowed....
Just use it as a learning experience.
Veggies and tofu are great, it's being vegan is retarded.
Learn to make the veggies stand up on their own and they become even better when teamed up with MEAT
  • Like 4
I don't think we have touched on the tax free threshold. (Thankfully as we have no reason to... although merowyn will be close this year with so much time off so we'll get there)
But yeah.... what a Muppet LOL
motorbike track guys are f**king nuts.
dez youre a crazy flamin mongrel.
one of my customers races them... flamin mongrel almost sliced his hand off lol
So about as dangerous as stealing a loaf of bread back in the old country eh...
  • Like 3
and this vegan lady you were trying to impress... more info please.
Not trying to impress... she was doing the pizza cooking, so I just hung out with a scotch and coke and let her.
I'm house sitting atm with her, if you really must stalk I'm tagged in a bunch of stuff with her on FB.
VWLStalkerClub, activate.
This made me laugh at my desk way too loudly... Have new noise cancelling headphones, can't tell exactly how loud I'm laughing or singing along to music. People stared.
  • Like 1
This one?
10945023_10153151830600649_2611260000808
  • Like 1
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
