yeah cold morning greasy tracka dn cold tyres with 600rwkw did not combo.
bounced off and the front corner tagged the concrete and did more damage than at the rear and and probally 1/4 the speed
if the tyre bundles were not there I would not have walked away let alone driven it again.
nah was keeping the semis for later in the day.
if I had chucked them on would have had enough grip to catch it.
was on some old bridgestones I had just to get the setting right first as the suspension was set for the 800 meters drags we did at nats.
then chase laps later. later didn't happen.
basically when I used to do driver training the main thing I worked on getting through to people is you have all day, work your way up...and then I did the opposite.
My high school life was split 1/2 between public and private,
all the dedicated drug addicts I know came from the private school. plus the guy who got convicted of attempted manslaughter (he did have a good excuses tho)
My private high was full of speed and weed, but nothing too heavy. Had a couple of ex addicts from Highvale (one was shooting up heroine in year 7, lulz, his inner elbow was a pin cushion at age 12). One of my former friends, well last I heard was in rehab for heroine but aside from that reasonably clean school. Private kids, rank generalisation but prolly have more access to monies to buy the more expensive gear? I imagine there are plenty of stoners in the public system but there's always gonna be some drug use in every school.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
