Zoolander - I know he wasn't the protagonist... but Mugatu was amazing
A good character but old school's screen time puts it ahead of Zoolander for me...not that I found much of that movie funny. Was a bit like Anchorman in that people quoted the shit out of it until you found it funny.
The man has only one look, for Christ's sake! Blue Steel? Ferrari? Le Tigra? They're the same face! Doesn't anyone notice this?
That was good though^
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
