Zoolander - I know he wasn't the protagonist... but Mugatu was amazing
A good character but old school's screen time puts it ahead of Zoolander for me...not that I found much of that movie funny. Was a bit like Anchorman in that people quoted the shit out of it until you found it funny.
The man has only one look, for Christ's sake! Blue Steel? Ferrari? Le Tigra? They're the same face! Doesn't anyone notice this?
That was good though^
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
