I heard that the old clip style ones were illegal as they protruded from the bonnet too much, but eh flush ones are ok?
just read the regs and yeah I think your right.
(last time I read was 10 years ago for my stang)
if they don't protrude your ok so the aero catch ones should be fine..
well unless a cop decided they are a pedestrian hazard.
so regs say:
  • Like 1
im keeping my stock latch + flat bonnet pins just for safety.
read something the other day of someone in Aus, those black flat bonnet pins stripped the thread on a racetrack straight, bonnet flew up and bent the roof :wacko:
Hmmm true true, but it's jsut a pain in the ass to have to unlock the pins, then pull the bonnet latch. Was hoping to remove catch all together so it's just a straight process of undoing pins. Not wanting to get defected for it though so thought 'd see if anyone has any info regarding
Need two secure points for the bonnet if you ever do any track days
Sorry for the noob question but what does that mean? I've got 2 bonnet pins on either side of the bonnet, but that's not what you mean is it? lol
Edited by T.D
i love the people that go on about Reps being deadly...
If half the national comp level drifters can use them and hit ripple strips sideways at 200kph without issues, somehow I doubt some phaggot in a VW doing 3kph to get up a wooden plank into shallow driveway to go to a circlejerk hardpark meet has anything to worry about
  • Like 3
yeah 2 bonnet pins is 2 separate anchor points.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
