You should definitely do DECA Greg. The 2.5 hour drive up there and back combined with a full day of high revving action is sure to end well
believe it or not, I actually made it there and back and did a beginner drift day complete with absolute rev smashing and didn't wreck the car until a week after!
Maybe you need to show your car hard love to get it liking you
I always found Skylines drove much better when you thrashed them rather than babied
They feel smoother and more licence losing
Kind of related
Trying to strike that balance between running down a fuel tank quickly so I can replace fuel pump and babying the car around so it doesn't kill the fuel pump, is a bitch
man forgive me for being so forward or if I've missed something but why is your car such a heap of shit? And surely it's not your everyday car if it's so unreliable?
i dont get some people (not you, well sort of.) who cant be bothered spending money on a licence.
"durhh i wanna do a deca or haunted hills, maybe do a track day sometime. how much of a cams licence?"
"$110"
"aww shit... gets pricey"
you just spent like a few grand on car bits ffs.
Haha yeah 'cbf' probably wasn't the right word it's more the spending money and renewing for one event, $110, $300 tyres, $120 deca etc etc
I'll have a think about it might come up anyway even if just watching / help time
Go at your own pace, don't worry about any other kunt, don't worry about who's behind you (easier said than done when you're one of the slower people in the group) but also don't be the flog who is painfully slow through the corners on his 1000cc then nails it down the straight and doesn't let you pass, only to hold you up with his unpredictable line into the next corner...
When you heading down?
Good tips! yeah I'll scope out the group think i'd do the slow-med to be safe not the med-fast group.
Heading down in September unsure of date yet (getting a voucher thing)
Kind of related
last time mine died was with a completely full tank.
that was a bitch to replace. previous times you knew it was coming, this one just stopped completely.
oh yeah price defs starts to add up. i see the licence as something you pay every year enabling you to attend an event whenever you can. though i understand people who wouldnt get enough use to justify it
I confess not knowing enough about electrical, but can someone explain to me why a submersible pump with a positive and negative lead running to it is never in danger of shorting or sparking and blowing up the whole car?
Obviously disconnect battery before working on it and turn on car / pump brake to discharge circuitry, but I still had a huge fear of something like that happening when I put this pump in first time around and started the car.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
