oh yeah price defs starts to add up. i see the licence as something you pay every year enabling you to attend an event whenever you can. though i understand people who wouldnt get enough use to justify it
In the scheme of things though, it's probably the cheapest part of motorsport.
If DECA is a regular thing now and we get 4 a year it's pretty well justified. Never know when you wanna go club racing and can just do it on a whim.
so the issue was that the new owners required CAMS insurance not ASAA that we had been running under
Cams took a look and said hell no, no way is that safe.
so a number of car clubs (SAUVic included) did some working bees to put up tyre bundles and such to get it across the line.
CAMS have now given the OK on a safety front
so we good to go.
Yeah I'm more inclined to do DECA rather than a tack day less wear on the car.. my brakes would be cooked and would want an intercooler before going on the track, at least with deca it's quick little stints
Even though my car would be woeful with the current tyres, it's Achilles heel (plus it's just big, and auto)
Getting new front AD08R's fitted up tomorrow, current ones are flat spotted after my sandown incident. :/
Entries will be available very soon, throwing together a quick and dirty online entry page at the moment.
  • Like 1
so we good to go.
I see
Well that is good news
What's with the big price increase? New owners charging more for rental? Though it's been a while since I've done deca so it may be more incremental than it seems to me
I see
last lot were 80-85 off top of head so yes it is an increase.
more rent, insurance cost more,
short of it is we will prob loose a small amount on it with the increase!
hahaha thats priceless. gifs deliver. P's plates is icing.
also the skidpan is so clean in those older vids...
Michaels V8 falcon was a lot of fun last time he went.
Note: couldnt find any ford crash gifs :(
Dunno what Achilles I have.. Sport 2? or something dunno lol
Would be shocking on the skidpan given that when I did it in my N/a 33 it span easily.. another 3x the power with shitter tyres.. hrm.
Simon seems a waste to scrap those fronts? how bad are they?
Edited by UNR33L
If anyone wants to buy cheaply I have some 265/18 R1Rs with fk all tread left and some KU31 235/18 with fair bit of tread but nearly fked shoulders
I'd put them on my car for deca but cbf
Is that geeen flog rattla?
I have RSR, Achilles 123S, R888 and RS3 sitting around now to work out what to run at deca..
supper happy fun times
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
    • To drain the Intake Heat Exchanger, there is a crappy drain plug in front of the driver's side front tyre: You should use the largest headed phillips screwdriver you had, and in my case I needed vice grips on the hose above as the plug was tight (tighter than it needed to be, since it has an o-ring seal).  After you have a tray down and open the drain, open the intake heat exchanger reservoir cap (drivers side one) and you should get a couple of litres of coolant To get to the radiator, you need to remove the plastic engine undertray. It is held on with a series of 10mm headed bolts and some clips. For the radiator, there is another type of crappy drain (kind of like a plastic banjo bolt) and you should attach a length of hose to direct the stream of coolant per this pic (otherwise the coolant hits the rad support and goes everywhere). The drain is on the rear of the radiator on the driver's side and a bit hard to find. Put a big tray or bucket down (5l won't be enough) and slowly unscrew the fitting by hand. You only want to remove it far enough for coolant to flow, it you unscrew it right out the whole fitting and direction pipe will come off and you will get a coolant bath (yum!). Undo the radiator reservoir cap and it should empty about 8l
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You also need to drain the intake heat exchanger to remove the radiator so you will need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. 2 other tools that really help dealing with coolant lines and spring clamps are Bent Needle Nose pliers Hose pliers Between them they will reduce the frustration (and injury) potential by about 1000% Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
