oh yeah price defs starts to add up. i see the licence as something you pay every year enabling you to attend an event whenever you can. though i understand people who wouldnt get enough use to justify it
In the scheme of things though, it's probably the cheapest part of motorsport.
If DECA is a regular thing now and we get 4 a year it's pretty well justified. Never know when you wanna go club racing and can just do it on a whim.
so the issue was that the new owners required CAMS insurance not ASAA that we had been running under
Cams took a look and said hell no, no way is that safe.
so a number of car clubs (SAUVic included) did some working bees to put up tyre bundles and such to get it across the line.
CAMS have now given the OK on a safety front
so we good to go.
Yeah I'm more inclined to do DECA rather than a tack day less wear on the car.. my brakes would be cooked and would want an intercooler before going on the track, at least with deca it's quick little stints
Even though my car would be woeful with the current tyres, it's Achilles heel (plus it's just big, and auto)
Getting new front AD08R's fitted up tomorrow, current ones are flat spotted after my sandown incident. :/
Entries will be available very soon, throwing together a quick and dirty online entry page at the moment.
  • Like 1
so we good to go.
I see
Well that is good news
What's with the big price increase? New owners charging more for rental? Though it's been a while since I've done deca so it may be more incremental than it seems to me
I see
last lot were 80-85 off top of head so yes it is an increase.
more rent, insurance cost more,
short of it is we will prob loose a small amount on it with the increase!
hahaha thats priceless. gifs deliver. P's plates is icing.
also the skidpan is so clean in those older vids...
Michaels V8 falcon was a lot of fun last time he went.
Note: couldnt find any ford crash gifs :(
Dunno what Achilles I have.. Sport 2? or something dunno lol
Would be shocking on the skidpan given that when I did it in my N/a 33 it span easily.. another 3x the power with shitter tyres.. hrm.
Simon seems a waste to scrap those fronts? how bad are they?
Edited by UNR33L
If anyone wants to buy cheaply I have some 265/18 R1Rs with fk all tread left and some KU31 235/18 with fair bit of tread but nearly fked shoulders
I'd put them on my car for deca but cbf
Is that geeen flog rattla?
I have RSR, Achilles 123S, R888 and RS3 sitting around now to work out what to run at deca..
supper happy fun times
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
