Do we reckon the numberplafea NOTA26 would be absolute cop bait?
I think any custom plates are cop bait. Stands out amongst the standard issue plates.
Maybe if you got NOT-026 in blue/white standard issue.
edit: looks to be taken.
NTA-026 is available haha
  • Like 1
Why do I get the feeling these commentators are the same people who on the other hand stated national debt wasn't a bad thing as long as money was being spent on good shit, when Labor was pushing shit uphill?
I have another plate in mind that is surprisingly available but it's much more obvious than NOTA26
I also really don't want to spend $500 on improving my chances of getting fked up
I like how the author considered the impact of the petulant Senate and the equally hostile electorate..............
http://ab.co/1BNXB1k #abcnews
Dezzmang? Surely you are a huge fan of this lol
More work for A grade electricians after they f**k your shit up. We won't be able to fix you being dead but it'll be a nice boost for the funeral industry too I guess
Not sure how cops could prove you don't have a rb26. I reckon any custom plate would lead to the same amount of hassle.
Go hard or go home, get the more obvious one. #yolo
Engine number could be a give away
This. SO MUCH THIS.
Why is it that every tradie thinks parking restrictions don't apply to them? I don't get to park on the road directly out the front of where I work... just like the rest of the country
in fairness, their utes/trucks store their work-gear & tools for the job. They cant be parking 500m down the road & running back/forth for tools etc
Their car is their tool; the location of your car whilst working at your office wont impact you other than arriving/leaving times.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
